29 Logo Printing
The image area must not exceed 98,304 pixels. (Keep in mind that a logo that is 512 x 384 pixels exceeds 98,304 pixels.)
The image width must not exceed 512 pixels.
The image height must not exceed 384 pixels.
The bitmap file must not exceed 8 kilobytes in size.
You can configure print tasks to print more than one logo (on either the Header or Trailer sections, or both). The printer loads one image at a time when printing a check, receipt, or credit card voucher. The time it takes to print depends on the number of images the printer has to load.
OPOS printers with multi-language cards installed
Configuring logo printing for OPOS printers is the same as other printers in the Simphony EMC.
For third-party printer installation instructions, access the vendor’s website.
Upload a logo to Simphony
Assign a logo to guest checks, customer receipts, and credit card vouchers
Set the printer to print the logo
Ensure the DIP settings for the printer's buffer are set to the higher value to accommodate the logo's additional data
Printer DIP and Memory Switch Settings contains more information on DIP settings.
