Configuring Property-Level Port Settings
Starting with Simphony 19.6, a Secure Port column is now available from the Simphony EMC modules listed below. ServiceHosts now listen on separate HTTP and HTTPS ports for peer communications.
Access the EMC and then navigate to each module by selecting the following:
  • Location, Setup, Property Parameters, Workstations tab
  • Location, Setup, Workstations, Service Host tab
  • Location, Setup, KDS Controllers, Service Host tab
  • Location, Setup, KDS Controllers, Backup Service Host tab
  • Enterprise, Setup, Service Hosts module
  • Enterprise, Setup, Interfaces module
The Secure Port number column is non-configurable by design. You should expect (and allow) increased network traffic from any ServiceHosts assigned to these secure ports.
Workstations running Oracle Linux for MICROS are preconfigured with firewall rules, and available ports are limited. If this feature is needed, then the firewall rules must be manually adjusted.
