Tax Parameters
The Tax Parameters module enables you to configure options related to taxes. You can configure the Tax Parameters module at the property, zone, or revenue center levels. The configuration varies depending on your local tax jurisdiction. Configuring Tax Parameters contains more information.
The following tables list all tax parameter options.
Table 13-4 Tax Parameters International Options
| International Options | Description |
1 - ON = Apply Tax as Add-On; OFF = Apply Tax as VAT |
Select this option to treat taxes as add-on. Deselect this option to treat taxes as a value added tax (VAT). If you enable VAT, all tax rates in use must be type Included, Percentage. |
3 - Print Tax Itemizers |
Select this option to print tax itemizers on guest checks and receipts. An itemizer is considered a bucket that holds the sale amount of all items taxed at a specific rate. At the end of a transaction, the tax is applied to the subtotal of all items in the bucket. Menu Item Classes are linked to Tax Classes, which in turn, are linked to Tax Rates 1-64. When you link to a tax rate, you are creating an itemizer bucket for that item. You must enable this option for Philippine tax. |
4 - Enable Canadian GST |
Select this option to enable Canadian Goods and Services Tax (GST). |
6 - Enable Thailand Tax Printing |
Select this option to enable Thai tax options. Starting with the Simphony 19.2.1 release, this option is not in use. |
9 - Japanese Tax Rounding: On = Truncate digits after decimal; Off = Round digits after decimal |
Select to truncate vs. round tax amounts as needed for Japanese tax. This option is superseded by International Tax option 21 - Enable Japanese Tax. |
13 - Truncate Inclusive Taxes |
This option applies to all inclusive tax calculations. It determines whether the inclusive tax amount that is calculated is rounded or truncated. For example, if a currency has two decimal places and the tax calculated is 12.005, the rounded tax is 12.01, but the truncated tax is 12.00. |
14 - Print Item Inclusive Tax Total |
If the check contains items with inclusive taxes, this option enables the total inclusive tax to print on the guest check. The line prints according to Tax Parameters option 4 - Print Inclusive Tax Totals when 0.00. The inclusive tax amount is the sum of the inclusive taxes for each item on the check. You must also select Tender/Media Printing Options 21 - Print Summary Totals and 24 - Print Inclusive Tax or VAT Lines on Check or Receipt for the inclusive tax totals to print. |
15 - Print Check Inclusive Tax Total |
If the check contains items with inclusive taxes, this option enables the total inclusive tax to print on the guest check. The line prints according to Tax Parameters option 4 - Print Inclusive Tax Totals when 0.00. The inclusive tax amount is calculated on the total sales for each tax rate. You must also select Tender/Media Printing Options 21 - Print Summary Totals and 24 - Print Inclusive Tax or VAT Lines on Check or Receipt for the inclusive tax totals to print. |
16 - Print Tax Rate per item |
Select to print the applied tax rates for each menu item on guest checks, customer receipts, and the journal. |
17 - Enable Tax Labels |
Select to consolidate tax reporting information based on the defined Tax Labels configured under Tax Rates. |
18 - Enable Australian GST. Post Inclusive Tax to Net Sales Totals |
Select to enable posting of net sales and the inclusive tax associated with it for Australian GST. |
19 - Service Charge Itemizer is Net of Inclusive Tax |
Select to net service charge and automatic service charge itemizers by menu item inclusive tax amounts. This reduces service charge totals calculated against those itemizers. |
20 - Add On Tax Calculates Net of Inclusive Tax |
Select to have add-on tax calculate on taxable sales net of inclusive tax. This results in a lower add-on tax calculation as the taxable sales value is reduced. |
21 - Enable Japanese Tax |
Select to apply Japanese tax behavior. Japanese tax truncates tax on the taxable subtotal instead of rounding by item total. It also prints tax values broken down by rate on guest checks, customer receipts, and journals. Japanese tax supports add on and inclusive tax rates, but they cannot be used together on the same check. Japanese tax requires that International Tax option 1 - ON = Apply Tax as Add-On; OFF = Apply Tax as VAT be selected. |
Table 13-5 Tax Parameters Options
1 - Do Not Include Tax in Totals on Tip Reports |
Select this option to prevent a transaction's calculated tax amount from posting to the gross receipts and charged receipts totals on tip reports. |
2 - Require a Reference Entry with Tax Exemptions |
Select this option to require workstation operators to enter a reference entry when using an exempt tax function key. |
3 - Print Inclusive Tax Lines Before Summary Totals |
Select this option to print inclusive tax total before summary totals on guest checks and customer receipts. |
4 - Print Inclusive Tax Totals when 0.00 |
Select this option to print inclusive totals on guest checks and customer receipts even if the calculated tax due is 0.00. |
5 - Print Consolidated VAT Line on Checks and Customer Receipts |
Select this option to print a consolidated VAT line. If you use this option in conjunction with individual VAT line printing, the consolidated line prints last. |
6 - Print VAT Net Totals on Guest Checks and Customer Receipts |
Select this option to print a VAT Net Totals line on guest checks and customer receipts. |
7 - Print Tax Exempt Voucher |
Select this option to print a voucher when any tax is exempted. The voucher prints when a tax exempt function key or a tender exempts tax. The voucher prints at the validation printer designated for the workstation. Deselect this option to suppress printing of a tax exempt voucher. |
8 - Post Taxable Sales When the Tax Rate is Zero |
Select this option to have taxable sales post to the TAX_DAILY_TOTAL table in Reporting and Analytics when the tax rate is set to 0.00%. The taxable amounts can be used for reporting even though there are no applied taxes. Deselect this option so that taxable sales do NOT post to Reporting and Analytics when the tax rate is set to 0.00%. |
9 - Prorate Tax for Each Combo Meal Menu Item Price as a Percentage of Total Combo Meal Price |
Select this option to prorate the menu item price of each combo meal item as a percentage of the total combo meal price in order to apply the correct amount of tax to each item. This option was implemented to satisfy tax requirements in France, Italy, Germany, and Austria. Tax calculations in other countries may not align with local fiscal requirements and should be validated before using this option. |
Parent topic: Taxes
