Section Layout
The optional Section Layout lets you create and administer Seating Section Layouts for table, section, and server assignments. Hosting staff can hide and recall the Section Layout from the Host Command Area or from a separate page.
Hosting staff can easily assign tables to a section when tables are present on the same page as the Section Layout. Tables are also accessible while editing a Section Layout.
The following figure shows an example of the Section Layout.
Figure 39-3 Section Layout
