Extension Application Installation
  1. In the EMC, select the Enterprise, property, revenue center, or zone, click Setup, and then click Extension Application.
  2. Insert a record for the extension application, enter Simphony_MenuItemInformation in the Record Name(s) field, and then click OK.
  3. Highlight the new record, and then click the Toggle Table/Form View icon on the EMC toolbar (The Toggle Table/Form View icon is a blue box on top of a white box.) to switch to form view.
    Figure 17-21 Extension Application Form View
    This figure shows an example of form view for the Extension Application record.
