Theme Assignment
The Theme Assignment module is where you configure the color palettes used by the POS client.
Where to access Theme Assignment: Enterprise, Zone, Property, or Revenue Center | Configuration | Theme Assignment
Role Access: Page Assignment
Role Privileges: View, Edit, Add Override
Views: Form view
Figure 9-18 POS Keyboard — Theme Assignment
Table 9-12 Theme Assignment Configuration Tab
| Field | Description | Data Type |
Default Theme |
Select the default theme for workstations:
List Choice |
Default Palette |
Select the default palette for the Edge theme:
List Choice |
Default Kitchen Display Theme |
Select the default theme for kitchen displays:
List Choice |
POS Keyboard Theme |
Select the theme for the POS keyboard:
List Choice |
