Data Extensions
Use the Data Extensions tab to view or configure fields added to the workstation record by installed extensions.
Table 8-12 Data Extensions tab fields
Field Description
Extension-defined fields
View or configure values added by an installed extension. Field names, values, and behavior depend on that extension.
