List of Widgets
You can add the following widgets to a Welcome or Home page. Welcome and Home pages do not support Hub page widgets.
Table 41-4 Welcome and Home Page Widgets
| Widgets for Welcome and Home Pages | Description |
URL Launcher
The URL Launcher enables you assign an image and a web address or URL to a tile. Tapping this tile takes you to the website. |
The Image widget enables you to assign an image or picture to a tile. Tapping this tile increases the image size and shows more detail. |
IP Camera Feed
The IP Camera Feed enables you to directly assign an IP camera feed to a tile. Tapping this tile increases the camera feed screen size. You do not need to assign an image to the tile. You can connect a maximum of three cameras. Creating Tiles (Adding Widgets to a Page) contains more information about the IP Camera Feed widget. |
PDF Viewer
The PDF Viewer widget enables you to assign a PDF to a tile. Tapping this tile opens the PDF document. Install a PDF reader application on the workstation to use this widget. |
The Twitter widget enables you to assign a Twitter feed to a tile. Tapping this tile increases the size of the Twitter feed view. |
Image Slideshow
The Image Slideshow widget enables you to assign multiple images that rotate for viewing at five-second intervals. |
Today’s Special
The Today’s Special widget enables you to assign one or more menu items, graphics, descriptions, and prices to a tile. When more than one menu item is configured, the items rotate for viewing at five-second intervals. You can assign a time range to this widget so that different specials cycle based on the times they are being served. |
Command Widget
The Command widget enables you to assign procedures, functions, and workstation commands to a tile. The available commands are:
Weather
The Weather widget enables you to assign a weather forecast provider and location to a tile. Purchase an application program interface (API) key to use this widget. |
You can add the following widgets to a Hub page.
Table 41-5 Hub Page Widgets
| Widgets for Hub Pages | Description |
ECM Alert
The ECM alert widget enables you to view ECM alerts based
on cash pull thresholds for till and server bank receptacles. This
widget is supported for multiple cash management classes. The ECM
alert widget shows:
The ECM alert widget also indicates when there are no active alerts. |
ECM Summary
The ECM summary widget enables you to view summary information
for active ECM receptacles. This widget is supported for multiple
cash management classes. The ECM summary widget shows:
The ECM summary widget also indicates:
inMotion Charts
The inMotion Charts widget enables you to assign Oracle Restaurants Enterprise Back Office reports to a tile. When you select this tile, the assigned report generates first, but all other reports are also accessible. Select each report to view more information. The following reports are available:
inMotion Stores
The inMotion Stores widget enables you to view cumulative sales report information from all available outlets, or you can select an individual store from a list that appears when selecting this tile. |
Labor Cost
The Labor Cost widget enables you to view potential employee overtime labor costs. When you select this tile, alerts inform the supervisor about employees approaching overtime for a particular pay cycle. |
WCC (Web Configuration Console)
The WCC widget enables you to assign one of the following available manager procedures to a tile:
