Closed Check Report Codes
The Status Indicator field prints to the left of the check number and indicates how the check was closed. Several entries can apply to the same check, and they are printed in a string. The following table lists and describes the Status Indicators for Closed Check Report Codes.
Table 33-3 Status Indicator Codes for Closed Check Report
Code Name Description
A
Add
The detail from this check was added to another check.
a
Add
The detail from this check was received from another check.
C
Canceled
The check was re-opened and immediately closed, using the Transaction Cancel key.
f
Fast Transaction
The check was created during a fast transaction.
j
Adjusted
The check was re-opened with the Adjust Closed Check key, and the tender or tip was adjusted.
R
Re-opened
This is the original check that was re-opened with the Reopen Closed Check key.
r
Re-opened
This is the check that was created when re-opening a check.
S
Split
This is the original check before it was split.
s
Split
This is the check that was created when splitting a check.
T
Training
This check was opened and closed by a workstation operator who was in training mode.
X
Transferred from check
The detail from this check was added to another check, which is in a different revenue center. This symbol appears only if the transfer was between revenue centers.
x
Transferred to check
The detail from this check was received from another check in a different revenue center.
Open on system
This check was accessed while it was open on the system.
O
Offline
This check was created offline.
B
Batched
This check was batched.
