Allowing Employees to Manually Replay Checks Through the Workstation
You need to grant employees permission to manually replay offline checks through the Property Management Console (PMC), if an offline workstation fails to automatically replay its checks before reconnecting online.
- Select the Enterprise level, click Configuration, and then click Roles.
- Double-click the role type record (for example, administrator or manager).
- Click the Operations tab, and then click the PMC General/Reports subtab.
- Select 30001 - Run PMC to allow employees associated with this role to launch the PMC on workstations using the Launch PMC function key.
- Click the PMC Procedures subtab, and then select 30069 - Replay Checks from the Other Procedure Options section.
- Click Save.
