PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Menu Level Sets for Conversational Ordering
Select the Enterprise, property, revenue center, or zone,
click Configuration, and then click Menu Level Sets.
Insert a new Menu Level Set.
In the coffee shop example, you could create Size and Temperature
Menu Level Sets.
Select the Default Master Group for
each Menu Level Set.
In the coffee shop example, you could select Drinks as the Default Master Group. When a workstation operators selects
a Menu Level in this group, Simphony determines which item of the
selected Menu Item Group to apply to the check.
Double-click a Menu Level Set to open it in form view.
From the General section, select 2 - Bound to
parent to bind the Menu Item Master Group (for example,
Drinks) to the custom Menu Levels (for example, Size and Temperature).
When a guest initially orders a drink by either Size or Temperature,
those menu items link to the Menu Item Master Group, which also link
to Anonymous Menu Level Entry Options. This enables the workstation
operator to add items in the exact order that the guest states or
orders them.
From the Menu Level Entries section, click Add.
Enter menu level names for the Menu Level Set (for example,
you could add Small, Medium, and Large Menu Level Entries to the Size
Menu Level Set).
For each Menu Level Entry, select the Default and Anonymous options.
Selecting these options enable the menu level sets to serve
as temporary $0.00 placeholders for menu items when guests order them
out of sequence.
