Configuring Right to Left Reading Languages
To show guest check detail and print customer receipts and guest checks in the right to left orientation configured for a language (for example, Arabic and Hebrew), set the following:
  • Enterprise Language
  • Workstation Language
  • Secondary Print Language
  1. Select the Enterprise level, click Setup, and then click Languages.
  2. Double-click the language record to open it.
  3. To show the check detail area and customer receipt on the workstation and print in right-to-left orientation, select Right-To-Left.
  4. To print Hebrew characters in the correct order, select Reverse Word.
  5. Click Save.
  6. Select the property, click Setup, and then click Workstations.
  7. From the Language drop-down list, select the language to appear on the workstation.
    You can override the default language on the workstation for specific employees using the Employee Maintenance module. Employees with a different language configured in Employee Maintenance see that language after signing in to the workstation.
  8. Click Save.
  9. Select the property, click Setup, and then click Property Parameters.
  10. From the Language 1 and Language 2 drop-down lists, select the primary and secondary languages.
  11. From the Select Secondary Print Language drop-down list, select the language.
    To print only the default language, select 0 - None. When printing multiple languages, the application prints item names in the order configured for the property.
  12. Click Save.
  13. Select the Enterprise, property, revenue center, or zone, click Setup, and then click Format Parameters.
  14. Click the Options tab, and then select 52 - Print Secondary Language on Guest Checks/Customer Receipt.
  15. Click Save.
