Creating Menu Item Classes for Prefixes
- Select the Enterprise level, click Descriptors, and then click Condiment Group Names.
- In the Text field, enter a group name to appear in the workstation for the condiment prefixes.
- Click Save.
- Select the Enterprise level, click Configuration, and then click Menu Item Classes.
- Insert a prefix record (for example, Add).
- Double-click the new record.
- On the General tab, select the Condiment Prefix Type.
Table 17-19 Condiment Prefix Types
Condiment Prefix Type Description 1 - Description Prefix
Describes the condiment it modifies (for example, Lite Mayo).
2 - No Prefix
Removes the default condiment (for example, No Cheddar).
3 - Add Prefix
Adds a non-default condiment (for example, Add American).
4 - Sub Prefix
Replaces a default condiment with a similar condiment (for example, Sub Swiss).
5 - Plain Prefix
Removes condiments from the menu item.
6 - Reset Prefix
Resets the menu item with default condiments.
7 - Clear Prefix
Removes multiple condiments from the menu item.
- Click the Options tab, and then select 2 - ON = Condiment Menu Items; OFF = Regular Menu Items.
- Click the Condiments Group tab.
- In the Member Condiment Groups section, select the condiment group that you created in Step 2.
- Click Save.
- Repeat Steps 5 through 11 to configure menu item classes for the remaining prefixes.
