PreviousNext
JavaScript must be enabled to correctly display this content
Setting the Condiment Display
Select the Enterprise, property, or revenue center, click Setup, and then click Format Parameters.
Click the Options tab, and then
select the appropriate options:
Table 17-20 Condiment Display Options on Checks, Receipts, and Workstation
Option
Description
35 - Hide Previous Round Condiments on Display
Hide previous round condiments and show only the parent
menu item when a workstation operator picks up a check.
45 - Sort Current Round Condiments on Screen
Condiment sorting occurs only when items are in different
print groups and the parent allows condiment sorting.
Set the
check detail area to sort condiments as they are added.
Click Save.
Select the Enterprise, property, or revenue center, click Setup, and then click Control Parameters.
To allow condiments to be added out of order (conversational ordering), click the Options tab, and then select 44 - Permit Required Condiments To Be Entered Out Of Order.
Click Save.
Select the revenue center, click Setup, and then click Order Devices.
Double-click a printer record, and then click the Options tab.
To print condiments in red font, select 10 -
Print Condiments in Red (Overrides Print Class Settings).
