PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Workstation Control Privileges
To set the control of workstation operations during critical events:
Select the Enterprise level, click Configuration, and then click Roles.
Select the role type (such as manager), click the Operations tab, and then click the Miscellaneous subtab.
Select the appropriate privileges:
10019 - Unlock UWS or Revenue Center: Select this option to allow employees in the role to unlock a workstation or revenue center from the locked dialog.
10020 - Use Workstation Control: Select this option to allow employees in the role to use the Workstation Control key to access various workstation functions (for example, locking and unlocking workstations and revenue centers, and updating the database). Selecting this option also allows employees to unlock a workstation or revenue center from the locked dialog.
Click Save.
Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
Select the page on which to place the Workstation Control button.
Add a Workstation Control button:
In the Legend field, enter Workstation Control.
From the Type drop-down list, select Function.
Click the arrow beneath the Type drop-down list, and then select Workstation Control.
