Disable Delivery Service Provider
If you no longer use a delivery service provider, you need to disable the interface for the platform that is not in use.
- Access Delivery Connectors from Simphony Home.
- Navigate to the location.
- Click the ellipsis (…) adjacent to the location, and then select Deactivate Connection.
