Configuring ECM Privileges and Permissions
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Select the role type (for example, administrator, manager or server), and then click the EMC Modules tab.
  3. In the Cash Management section, select the appropriate Cash Management operation permissions for the user role. You can grant permissions for the following actions:
    • View: Open and view a Cash Management module. If you allow a user to Edit, Add, or Delete, you must also grant View access (otherwise the user cannot open the module).
    • Edit: Update fields or records within a module.
    • Add: Add records to a module. You cannot add records to the Cash Management Class Behavior module.
    • Delete: Delete records from a module. You cannot delete records from the Cash Management Class Behavior module.
    • Add Override: Override records in a module. You cannot override records in the Cash Management Classes module.
  4. Click the Operations tab, and then click the Cash Management subtab.
  5. Select the appropriate options for the privileges. The following table summarizes the privileges associated with ECM functionality and the recommended roles to have the privilege set.
    Table 40-2 ECM Privileges
    Section Option Number Privilege Name Allow the Employee to Perform or Authorize... Recommended Role(s)
    General Operations
    249
    Change Count Sheet
    Changing the count sheet that the receptacle session uses
    Manager
    General Operations
    250
    Pull Cash
    A cash pull
    Cashier, Manager
    General Operations
    258
    Threshold Level Exception
    A Cash Pull Threshold Exception (bypass the threshold notification) when prompted and permitted
    Manager
    General Operations
    260
    View Receptacle Session Status
    Viewing of summary information for all active receptacle sessions
    Manager
    General Operations
    267
    Update Balance on Count
    Updating the balance on a count when the amount is outside the count threshold values
    Manager
    General Operations
    301
    View Cash Management Dashboard
    Viewing the Cash Management Dashboard page
    Manager
    General Operations
    302
    View Cash Management Dashboard Detail
    Viewing the till and server bank detail from the Cash Management Dashboard page
    Manager
    Till Operations
    201
    Assign Till to Cash Drawer
    Assignment of a till to a cash drawer on a workstation
    Manager
    Till Operations
    202
    Unassign Till from Cash Drawer
    Unassignment of a till to a cash drawer on a workstation
    Manager
    Till Operations
    203
    Assign User to Till
    Perform or authorize the assignment of an employee to an active till session
    Manager
    Till Operations
    204
    Unassign User from Till
    Unassignment of an employee to an active till session
    Manager
    Till Operations
    205
    Count Till
    Counting of a till session
    Cash Handler
    Till Operations
    206
    Adjust Till Count
    Adjustment of the last count for a till session
    Manager
    Till Operations
    207
    Paid-In/Paid-Out
    Posting of an ECM paid-in or paid-out on a till session
    Workstation operators can perform standard paid-in and paid-out transactions based on Tender/Media configuration.
    Manager
    Till Operations
    209
    Transfer Funds
    Transfer of items from a till session to another cash receptacle session
    Cashier, Manager
    Till Operations
    210
    Deposit Funds
    Deposit of cash from a till session to a bank deposit session
    Cash Handler
    Till Operations
    212
    Close Till
    Closing of a till session
    Cash Handler
    Till Operations
    213
    Reopen Till
    Reopening of a till session
    Manager
    Till Operations
    251
    Quick Start Till
    Opening of a till session and assignment of the current operator to a workstation cash drawer
    Cash Handler
    Till Operations
    259
    Adjust Till Starting Amount
    Adjustment of the till starting amount
    Manager
    Server Bank Operations
    241
    Start Server Bank
    Opening of a new server bank session
    Manager
    242
    Count Server Bank
    Counting of a server bank session
    Manager
    243
    Adjust Server Bank Count
    Adjustment of the last count for a server bank session
    Manager
    244
    Paid-In/Paid-Out
    Posting of an ECM paid-in or paid-out on a server bank session
    Manager
    245
    Transfer Funds
    Transferring of funds from a server bank session to another cash receptacle session
    Manager
    246
    Deposit Funds
    Deposit of cash from a server bank session to a bank deposit session
    Manager
    247
    Close Server Bank
    Closing of a server bank session
    Manager
    248
    Reopen Server Bank
    Reopening a closed server bank
    Manager
    265
    Adjust Server Bank Starting Amount
    Adjustment of the server bank session starting amount
    Manager
    269
    Consolidate Server Banks
    Consolidating two server bank sessions
    Manager
    Safe Operations
    214
    Open Safe
    Opening of a new safe session
    Manager
    Safe Operations
    215
    Count Safe
    Counting of a safe session
    Manager
    Safe Operations
    216
    Adjust Safe Count
    Adjustment of the last count for a safe session
    Manager
    Safe Operations
    217
    Paid-In/Paid-Out
    Posting of an ECM paid-in or paid-out on a safe session
    Manager
    Safe Operations
    218
    Transfer Funds
    Transferring of funds from a safe session to another cash receptacle session
    Manager
    Safe Operations
    219
    Deposit Funds
    Deposit of cash from a safe session to a bank deposit session
    Manager
    Safe Operations
    220
    Close Safe
    Closing of a safe session
    Manager
    Safe Operations
    261
    Add Funds to Safe
    Adding new funds into ECM through a safe receptacle
    Manager
    Safe Operations
    262
    Remove Funds from Safe
    Removing funds from ECM through a safe receptacle
    Manager
    Petty Cash Operations
    222
    Open Petty Cash
    Opening of a new petty cash session
    Manager
    223
    Count Petty Cash
    Counting of a petty cash session
    Manager
    224
    Adjust Petty Cash Count
    Adjustment of the last petty cash session count
    Manager
    225
    Paid-In/Paid-Out
    Posting of an ECM paid-in or paid-out on a petty cash session
    Manager
    226
    Transfer Funds
    Transferring of funds from a petty cash session to another cash receptacle session
    Manager
    227
    Deposit Funds
    Deposit of cash from a petty cash session to a bank deposit session
    Manager
    228
    Close Petty Cash
    Closing of a petty cash session
    Manager
    Bank Deposit Operations
    233
    Create a Bank Deposit
    Opening of a new bank deposit session
    Manager
    234
    Transfer Funds
    Transferring of funds from a bank deposit to another cash receptacle session
    Manager
    237
    Adjust Cash Deposit
    Adjustment of a cash deposit amount in a bank deposit session
    Manager
    239
    Reconcile Bank Deposit
    Reconciliation of a bank deposit session
    Manager
    264
    Adjust Bank Deposit Reference
    Adjustment of a reference on a bank deposit session
    Manager
    Change Order Operations
    230
    Create Change Order
    Creation of a new Change Order request from a safe session
    Manager
    232
    Reconcile Change Order
    Reconciliation of a Change Order
    Manager
    252
    Submit Change Order
    Submission of a new Change Order request from a safe session
    Manager
    268
    Save / Recall Change Order
    Saving or recalling a Change Order
    Manager
  6. Click Save.
