Enabling Events
You need to enable events to associate transactions with events and to use event reporting.
  1. Select the property, click Setup, and then click Property Parameters.
  2. Click the Options tab, and then select 51 - Enable Events Reporting.
    When option 51 is enabled, workstation operators are prompted for each newly opened check. If Control Parameters option 67 - Association of an Event to every Guest Check is mandatory where Event is enabled is disabled, from the Select Check Event window, click None and then click Ok to proceed with the order. If option 67 is enabled, workstation operators must select an event; if events do not exist, a No events to select message appears.
  3. Click Save.
