Configuring the Event Status Bar
To allow workstation operators to see the event and check details to which sales are posting, you need to add the event status bar to the transaction page, and configure the event information that appears in the status bar.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Open the page on which to place the event status bar (typically the transaction page).
  3. Click the Configuration tab.
  4. Select one or both of the following placement options:
    • Top Status Bar
    • Bottom Status Bar
  5. Click the Add button in the lower area.
  6. From the Add Status Bar Element dialog, select Operator Current Event Name for each of the following POS workstation state drop-down lists, and then click OK.
    • Signed Out
    • Signed In
    • In Transaction
  7. Repeat Steps 5 and 6, selecting the following elements for each workstation drop-down list:
    • Operator Current Event Shortcode
    • Operator Current Event Actual Start Date Time
    • Operator Current Event End Date Time
    • Check Current Event Name
    • Check Current Event Shortcode
    • Check Current Event Actual Start Date Time
    • Check Current Event End Date Time
  8. Click Save.
