Extension Application Content
Access the EMC, navigate to the Extension Application module, and then follow the steps below to configure the Version and Host Type columns for this extension application’s content.
SIM File Access Service
If your extension application uses the SIM File Access service, you must declare where the files are located.
To add paths:
Click SIM File Access.
Enter the path where the files are located on the device that hosts the SIM File Access Service.
Click Add.
Repeat for each required path.
Click OK when complete.
To remove paths:
Select the path to remove.
Click Delete.
Save the extension application when you finish editing the paths.
