Configuring Automatic Check Firing (Autofire)
- Select the revenue center, click Setup, and then click RVC Parameters.
- Click the Autofire tab, and then
configure the fields as described in the following table:
Table 23-2 Automatic Check Firing Fields
Fields and Options Description (Optional) Autofire Employee
To allow a specific employee to become the owner of all checks, including those placed using Transaction Services after the orders fire, select a workstation operator, and then click OK.-
If you select an Autofire Employee, all sales totals post to the designated workstation operator and the checks appear under the Autofire Employee in the Open Check Report.
If you do not select an Autofire Employee, the check operator remains the owner of the check after the order fires.
Autofire Workstation
Select the workstation from which the orders fire and print. The application uses this value to determine the order output devices and workstation printers to use when an order fires.
Default Autofire Tender/Media
Select a service total that workstation operators can use with Autofire.
You can assign any service total. Oracle recommends configuring a separate service total for automatic order firing to allow workstation operators to identify the designated touchscreen button. Creating a Service Total to End the Current Round of Checks contains information about configuring a service total.
Backup Autofire Delay (Mins)
Enter the amount of time (in minutes) that the autofire workstation must try to fire the orders.
After the Backup Autofire Delay time elapses, if the autofire workstation is unsuccessful at firing the order, the workstation at which the check was originally created tries to fire the order. If both workstations fail, a memo chit prints and a workstation operator must manually fire the order.
(Optional) Maximum Days
Enter the maximum number of days for which workstation operators can schedule orders to fire automatically.
(Optional) 1 - Print Autofire Memo at Time of Entry
Select this option if you want a memo chit to print when workstation operators create orders that fire automatically.
(Optional) 2 - Print Guest Check at Time of Autofire
Select this option if you want a guest check to print when an order automatically fires to order devices.
If you select this option, guest checks print at the guest check printer assigned to the autofire workstation.
3 - Enable Autofire in this Revenue Center
Select this option to allow the revenue center to create orders that fire automatically.
If you are using Dynamic Order Mode (DOM), do not enable Autofire or hold and fire.
- Click Save.
- Select the Enterprise, property, revenue center, or zone, click Descriptors, and then click Autofire Check Offline Header.
- From the Text column, enter the header lines to print on memo chits when orders fail to fire automatically.
- To add a logo to the header, select Use Logo, click the ellipsis point (...) button from the Logo column, select the logo from the list, and then click OK.
- Click Save.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Insert a new button on the transaction page, select Function from the Type drop-down list, and then select Begin Autofire Check from the Function list.
- Click Save.
