Copying Translations from One Language to Another
- Select the Enterprise, click Setup, and then click Languages.
- Double-click the appropriate language record to open it, and then click the Translations tab.
- To copy all translations from another language, click Copy All Translations, select the language from which to copy, and then click OK.
- To copy the translations for selected elements:
- From the Text Element section, select the relevant records, and then click Copy Selected Translations.
- Select the language from which to copy, and then click OK.
- Click Save.
Parent topic: Definition Translations
