Configuring Translation Privileges
To enable privileges so that users can modify, import, or configure language translations, perform the following steps.
  1. Select the Enterprise, click Configuration, and then click Roles.
  2. Double-click the role type, click the Actions tab, and then select the appropriate privileges:
    Table 6-2 Translation Privilege Settings
    Privilege Name Allows the Employee to... Recommended Roles
    EMC Text Translations
    Import and modify the EMC related text files
    Property expert
    Workstation Text Translations
    Import and modify workstation related text files
    Property expert
  3. Click Save.
