Configuring the Loyalty Module
- Select the Enterprise, property, or revenue center, click Setup, and then click Loyalty Module.
- Insert a record, enter LoyaltyModule as the name, and then click OK.
If you are using Valutec, you can name the module record VTLoyaltyModule.
- Double-click the record to open it.
- On the General tab, click the Import from a file link.
- Browse to [Drive Letter]:\MICROS\Simphony2\EgatewayService\handlers,
select LoyaltyCommandModule.dll, and then click Open.
If you are using Valuetec, select VTLoyaltyCommandModule.dll, and then click Open.
- Click the Configuration tab.
- In the Assembly/Class section, enter information in the
following fields:
Module ID: Enter a value that identifies the module. For Valutec, enter
VTLoyaltyModule. -
Display Name: Enter a name for the module (for example,
LoyaltyorVTLoyalty). -
Description: Enter a description of the loyalty module. Do not leave this field blank.
- In the Common Properties section, enter information in
the following fields:
Currency ISO Code: Enter the code (three alpha characters) that represents the currency being used (for example, USD).
See http://www.currency-iso.org/en/home/tables/table-a1.html for a list of Currency ISO 4217 codes.
Language ISO Code: Enter the code (two alpha characters) that represents the language being used (for example, EN).
See http://www.loc.gov/standards/iso639-2/php/code_list.php for a list of Language ISO 639-1 codes.
If the currency or language is different at the property, override these values at the property level.
- In the Loyalty Module Properties section, enter information
in the following fields:
Account Number Maximum Length: Enter the maximum length of a loyalty account number (up to 24 digits).
Account Number Minimum Length: Enter the minimum length of a loyalty account number (down to 7 digits).
Cash Module Name: Enter the name of the cash module to use for redemptions (for example, Cash:Cash).
- Click Save.
- Select the property, click Setup, and then click Loyalty Driver.
- Double-click the gift and loyalty driver record to open it.
- Click the Override This Record link, and then click Yes to confirm.
- From the iCare Driver Properties section, enter information
Login: Enter the login for the property ID or the login for the provider.
Password: Enter the password for the property ID or the provider.
- Click Save.
