Configuring a Smart Key to Show Menu Level Buttons
You can configure a smart key that workstation operators use to change menu levels. Define a smart key on the page containing the Condiment/Combo Orderer and set the main and sub level buttons for only small, medium, and large levels to appear when a combo side item with a default menu level is active. The buttons disappear from the page when the combo meal moves to the next side item or is complete. The smart key is only active while adding a combo meal side with a default menu level.
Follow these steps to implement the smart key.
  1. Select the Enterprise, zone, property, or revenue center, click Configuration, and then click Page Design.
  2. Select the page that has the Condiment/Combo Orderer. This is typically the Transaction page that also has the combo menu items and function keys.
    Creating Combo Meal Pages contains information about configuring the Condiment/Combo Orderer.
  3. On the Edit tab, click Button.
  4. Enter information in the Page Design fields.
    Table 17-26 Page Design Edit Fields
    Field Entry
    Legend
    Enter the name of the button (for example, Smart Key).
    Type
    Select Function from the drop-down list.
    Sub Type
    Click the black arrow, and then select Smart Key.
    Auto Active
    Select this option to make the button automatically active.
  5. Click the Edit Smart Keys button.
  6. Click Add.
  7. Enter information in the fields as described in the following table for the Main Level smart key.
    Table 17-27 Smart Key 1 Fields
    Field Smart Key Entry
    Condition
    Select Combo Side Default Level Active from the drop-down list.
    Value
    Enter 1.
    Legend
    Enter the name of the button (for example, Small, Medium, or Large).
    Type
    Select Main Menu Level from the drop-down list.
  8. Click Add.
  9. (Optional) Enter information in the fields as described in the following table for the Sub Level smart key.
    Table 17-28 Smart Key 2 Fields
    Condition
    Value
    Enter 2.
    Legend
    Enter the name of the button.
    Type
    Select Sub Menu Level from the drop-down list.
  10. Click Close.
  11. Click Save.
