Setting Main, Sub, and Custom Menu Levels
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Menu Level Sets.
    The Type column specifies whether the Menu Level Set refers to the Main Levels, the Sub Levels, or to the levels defined within the record. Main Levels and Sub Levels are not configured in this module. However, you can create an entry for the entire Main Level Set and Sub Level Set in this module; this allows you to configure the Options and Default Master Group fields for Main and Sub levels.
  2. To create a custom menu level, insert a new record, and then enter a custom level set name.
  3. To define main menu levels, double-click Main.
  4. To define sub menu levels, double-click Sub.
  5. To define menu levels for a custom level set, double-click the new custom level that you created in Step 2.
  6. Select the appropriate options:
    1. To change the menu level to the default level when the workstation operator presses a touchscreen button corresponding to any menu level in this menu level set again, select 1 - Pressing level key again reverts to default level.
    2. If the menu level set is bound to a Default Master Group and you want the workstation to switch the active parent menu item when the active menu level changes, select 2 - Bound to parent.
  7. (Optional) Select the Default Master Group for the menu level set.
    This field is used for conversational ordering. If a Default Master Group is assigned, when a Menu Level in this group is pressed, Simphony determines which item from the selected Menu Item Group (if any) to apply to the check.
  8. In the Menu Level Entries section, define the menu levels.
    You can use Menu Levels to specify menu item sizes, such as Small, Medium, and Large, and serving periods, such as Happy Hour.
  9. (Optional) Enter the Prefix or Suffix for each menu level to show on the check detail area and print on guest checks and customer receipts.
  10. To define a menu level as the default level for the menu level set:
    1. In the Options column, click the ellipsis point (...) button adjacent to the default menu level.
    2. Select 1 - Default, and then click OK.
  11. To define a menu level as an anonymous level for the menu level set:
    1. In the Options column, click the ellipsis point (...) button adjacent to the anonymous menu level.
    2. Select 2 - Anonymous, and then click OK.
    The Default and Anonymous menu levels are generic, and are typically used with $0.00 priced menu item definitions that have names such as [SIZE] Hot Drink or [TEMP] Drink.
  12. Click Save.
