Configuring Waste Receipt Headers and Trailers
When you post a waste check, the guest check printer assigned to the workstation prints a waste receipt.
  1. Select the Enterprise level, and then click Descriptors.
  2. Select one of the following options, depending on whether you want to configure receipt headers or trailers:
    • Waste Receipt Headers
    • Waste Receipt Trailers
  3. Perform one of the following actions:
    • Enter text for the header or trailer in the rows of the Text column.
    • Select a checkbox in the Use Logo column, and then select a logo using the ellipsis point (...) button in the Logo column.
  4. Click Save.
