Generating the Module Reference Report
  1. Select the Enterprise level, click the Tasks tab, and then click Module Reference Report.
  2. Select the appropriate Report Type:
    • By Name: Select to search for menu items by name.
    • By Number: Select to search for menu items by record number.
  3. Click Select Items for Report, select the menu item names or numbers to include in the search, and then click OK.
    Select multiple menu items by pressing the Ctrl or Shift key while selecting an item. You can select a maximum of 50 items at a time.
  4. Click Run Report by Name or Run Report by Number to generate the report.
  5. To print the report, click the Text View tab, and then click Print.
  6. To save the report as a text file, click the Text View tab, click Save as Text File, and then enter the file name and browse to the location to save the file.
