Creating SPI Gift Card Buttons
You can create buttons on a workstation page for the SPI gift card functions.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
  2. Open the page on which to place gift card buttons.
  3. On the Edit tab, select the page area in which to define the gift card functions (typically the payment or function area).
  4. Click Button.
  5. On the General subtab, select Payment Tenders from the Type drop-down list.
  6. Click the black arrow beneath the Type drop-down list.
  7. Select 0 - None, and then click OK.
  8. In the Payment Configuration dialog, select CreditDebit:Loadable from the Payment Type drop-down list.
  9. Select Balance Inquiry from the Functions drop-down list, and then click OK.
  10. Position and size the button on the page. Use the Style arrow to change the color.
  11. In the Legend field, enter the button name (for example, Gift Card Balance Inquiry)
  12. Click Save.
  13. Repeat steps 4 through 12 to create buttons for each gift card function listed in the following table. Select the corresponding function shown below from the Functions drop-down list in Step 9.
    Table 35-8 Gift Card Buttons
    Button Name Function
    Issue Gift Card
    IssueGiftCard
    Activate Gift Card
    ActivateGiftCard
    Reload Gift Card
    ReloadGiftCard
    Cash Out Gift Card
    CashoutGiftCard
