Configuring Employee Privileges for the Fingerprint Reader
- Select the Enterprise level, click Configuration, and then click Roles.
 - Select the role type, click the Operations tab, and then click the PMC General/Reports subtab.
 - To allow employees associated with the role to open the Property Management Console (PMC) using function key 300, select 30001 - Run PMC.
 - Click the PMC Procedures subtab.
 - Select 30055 - Assign Employee Fingerprint Scan and 30052 - Assign Employee PIN.
 - Click Save.
Parent topic: Fingerprint Scanning
