Configuring a Magnetic Stripe Reader
  1. Select the property, click Setup, and then click Workstations.
  2. Double-click the workstation to be used with the MSR.
  3. Click the Options tab, and then click the Display/Security subtab.
  4. Select the appropriate MSR options.
    Table 8-19 MSR Workstation Options
    Option Description
    12 - Mag Card Entry Required for Employee ID
    Select this option to allow all employee ID entries at the workstation to be made by swiping a magnetic employee ID card. The workstation does not accept an employee ID number entered through the keyboard or touchscreen.
    50 - Mag Card or Fingerprint Scan Required for Employee ID
    Select this option to allow all employee ID entries at the workstation to be made using a fingerprint scan or by swiping a magnetic card. That is, employees must swipe a card or scan a fingerprint.
    51 - Mag Card and Fingerprint Scan Required for Employee ID
    Select this option to allow all employee ID entries at the workstation to be made using a fingerprint scan and by swiping a magnetic card. That is, employees must both swipe a card and scan a fingerprint.
  5. If you are using an encrypted MSR (for example, the MSR sleeve for Oracle Tablet E-Series 8-inch and 11-inch devices with Transaction Vault Second Generation (TV2G)), note the following:
    Simphony 19.1 and later no longer support the option 55 - Enable Encrypted Magnetic Stripe Reader Support. Starting with Simphony 19.5, a workstation restart is required to disable the option if it was previously enabled on an earlier Simphony version.
  6. Click the Devices tab.
  7. Click Add, and then select a magnetic stripe reader from the Select Peripheral Device Type drop-down list.
  8. Select the COM Port Settings (if necessary), and then click OK.
  9. Click Save.
