PreviousNext
JavaScript must be enabled to correctly display this content
Configuring the Wireless Signal Strength Threshold for Tablet
Devices
Perform one of the following, depending on which level
you want to configure or override:
To configure at the property level, select the property, click Setup, and then click Property Parameters.
To override at the workstation, select the property, click Setup, and then click Workstations.
On the General tab, in the Wireless
Signal Strength Control section, enter information in the following
fields:
Offline Threshold: Enter a number between
0 and 99 to represent the signal strength percentage at which devices
go offline. Devices will go offline when the signal strength is at
or below this percentage value. For example, if the Offline
Threshold is set to 90 (90%), and the device’s current
signal is 89%, the device will go offline. When the signal is detected
above 90%, the device reconnects online.
Reconnect Threshold: Enter a number
between 0 and 99 to represent the signal strength percentage at which
devices recover online after being in an offline state. Devices will
go online when the signal strength is at or above this percentage
value. For example, if the Reconnect Threshold is set to 80, and the device’s signal strength is 85%, the device
will go online.
These values appear in a status bar on the workstation.
