Configuring Effectivity for Reservation Periods
  1. Select the revenue center, click Setup, and then click Reservation Periods.
  2. Insert a record for the reservation period (for example, Weekday or Weekend).
  3. Double-click the record to open it.
  4. On the Effectivity tab, select the appropriate options as described in the following table.
    Table 39-15 Effectivity for Reservation Periods
    Option Description
    Effectivity Start Date
    Select the first calendar day that the reservation period is effective. Deselecting the start date causes the reservation period for the reservation and wait lists to remain in effect indefinitely.
    Effectivity End Date
    Select the last calendar day that the reservation period is effective. Deselecting the end date causes the reservation period for the reservation and wait lists to remain in effect indefinitely.
    Recurrence Day Of Week
    Select the effective days of the week within the reservation period. You must select at least one day in order to save the reservation period.
    Recurrence Time Of Day
    Select the time of day that is effective in the reservation period.
    Deselecting the Active Start Time causes the reservation period for the reservation and wait lists to remain in effect starting at 00:00:00 on the applicable calendar days.
    Deselecting the Active End Time causes the reservation period for the reservation and wait lists to remain in effect until 23:59:59 on the applicable calendar days.
  5. Click Save.
