Creating Support Session Buttons
You can use the Page Design module to create two touchscreen buttons that launch or close a remote support session from a workstation page other than the Property Management Console (PMC) Support page. (The Launch Support Session and Close Support Session buttons automatically appear on the workstation PMC Support page without requiring configuration.)
