Sign In to Simphony Home
You can access Delivery Connectors from Simphony Home. To access Simphony Home, use the URL that was provided by Oracle. If you are unable to locate your Simphony Home URL (OpenID Provder URL), it’s located in the EMC Enterprise Parameters module, Applications subtab.
When copying this URL for access to Simphony Home, exclude the/oidc-provider/ portion
of the URL.
                     Parent topic: Deliveroo
Parent topic: DoorDash
Parent topic: Rappi
Parent topic: Skip
Parent topic: Uber Eats/Postmates
