Uploading Table Images
Table images show a graphical representation of the table and chairs. These images can be a square or round table surrounded by any number of chairs.
Table decoration images (or decorators) show a graphical representation of the table status (for example, dirty, closed, or reserved).
You can upload custom images to the Simphony application to represent enhanced table seating configuration and statuses. The TMS uses both custom images and images packaged with Simphony. All images are transparent Portable Network Graphics (PNG) files.
- Select the Enterprise, property, or revenue center, click Setup, and then click Content.
- Double-click the content name row to view the image set for the name.
- Click the Import from a file link to import custom images into Simphony.
- Browse to the file location, select the image file, and then click Open.
- Repeat Steps 2 through 4 to import each table image and table decoration image.
- Click Save.
Parent topic: Table Images
