PreviousNext
JavaScript must be enabled to correctly display this content
Assigning a Server to a Check Name
Select the Enterprise, property, or revenue center, click Configuration, and then click Employee Maintenance.
Search for and then highlight the employee record.
In the Check Name field, enter the
server’s name as you want it to appear on the workstation touchscreen
page.
If you do not enter a Check Name,
the workstation shows a blank name.
Select the Revenue Center in the
drop-down list in the left pane.
Click the Operator Records subtab
in the lower area of the screen.
In the TMS Color field, select the
color to distinguish the server from other servers on the host page,
and then click OK.
Although you can set a different color for each revenue center
within a property, Oracle recommends that you use a single color for
the server across the property. If you do not set a TMS Color, the
workstation shows white.
In the Server Efficiency field,
enter 0 (zero) to have the Simphony TMS ignore
the server in table suggestions.
The table suggestion (within TMS) sets the Server
Efficiency rating to determine the next table recommended
for seating. This rating is a value between 0 (zero) and 100, and
represents the number of covers that the server can efficiently service
at one time.
