Adding Enhanced Dining Tables to a Page
You can use all functions of the Simphony Table Management System (TMS) with enhanced tables. (You can’t use TMS with standard tables.) Enhanced tables show overlays on the outer edges of the table that indicate status, coursing, and alerts.
  1. Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
  2. Double-click the page on which to define enhanced dining tables.
  3. On the Edit tab, select the page area on which to place the enhanced dining tables.
  4. Click Other..., select Table Management, and then select Dining Table (Enhanced).
  5. Move and adjust the table size on the page. Leave space between tables on the page layout to ensure visibility of indicators and table state. You can increase the grid configuration on the page from 24 (default) to 48 using the Change Grid Size link.
  6. Set the unique properties of the enhanced dining table:
    1. Enter the table number in the Table # field.
      This number must match the Table Number set in the Tables module. See Configuring Enhanced Tables for more information.
    2. From the Next Page/Panel section, click the black Panel arrow, and then select the host page from the list.
    3. (Optional) Enter a table number in the Legend field.
      If the Legend is blank, the table number or name shown on the host page uses the table number or name defined for the Table # field. To use a different name or number for the table, enter an override value in the Legend field.
  7. Repeat Steps 4 through 6 to add more enhanced tables.
  8. Click Save.
