PreviousNext
JavaScript must be enabled to correctly display this content
Configuring the Host Command Area
Select the Enterprise, property, or revenue center, click Configuration, and then click Page Design.
Double-click the page on which to define the Host Command
Area.
On the Edit tab, select the page
area on which to place the Host Command Area.
You must place the Host Command Area in the same content
area on the page as the enhanced tables in order for the host features
to function.
Click Other..., select Table Management, and then select Host Command
Area.
Hosting staff performs a long button press on the Host Command
Area to access the TMS functions. As such, carefully consider the
Host Command Area sizing and placement to ensure that hosting staff
can easily see and press this area on the workstation.
The Host
Command Area can optionally show an image in place of the silver portion
of the area. You can set the image from the TMS Parameters module
as the Dining Table Decoration Image Name. The image you select scales
to the size of the Host Command Area. See Setting Table Decoration Images for more information.
