Configuring Smart Keys
Smart keys call multiple functions based on a set of conditions. For example, the same key can be configured to start an autofire check if the order channel condition is 'Delivery', and to begin a fast transaction if the order channel condition is 'To Go'.
Smart keys are not supported on handheld workstation devices.
  1. Select the Enterprise, zone, property, or revenue center, click Configuration, and then click Page Design.
  2. Select the page where the smart key button is to be accessed.
  3. On the Edit tab, click Button.
  4. Enter information in the following Page Design fields.
    Table 9-5 Page Design Edit Fields
    Field Entry
    Legend
    Enter the name of the button.
    Type
    Select Function from the drop-down list.
    Click the black arrow beneath the Type drop-down list, select Smart Key, and then click OK.
  5. Click the Edit Smart Keys button.
  6. Click the Add button.
  7. Enter information in the fields as described in the following table.
    Table 9-6 Smart Key Entry Button 1
    Field Smart Key Entry
    Condition
    Select a condition name from the drop-down list.
    Value
    Enter the object number or numbers for the condition, separated by commas.
    Legend
    Enter a description for this condition.
    Type
    Click the black arrow beneath the Type drop-down list, select the function that will be run if this condition is met, and then click OK.
  8. Click the Add button to add another condition.
  9. Enter information in the fields as described in the following table.
    Table 9-7 Smart Key Entry Button 2
    Condition
    Value
    Legend
    Type
  10. Click the Close button.
  11. Click Save.
  12. Configure as many smart key entry buttons as required.
