Assigning Conditional Touchscreen Pages
You can configure other touchscreen pages to appear instead of default pages based on conditions such as menu levels, serving periods, employee class, and other criteria. For example, if the order type is Take Out, display the transaction touchscreen page with take out items and prices called Take Out instead of the default transaction touchscreen page.
  1. Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Assignment.
  2. Click the tab for the page that you want to add a condition to:
    • Login
    • Home
    • Transaction
    • Training Home
    • Training Transaction
    • Welcome
    • Hub
  3. Select Add in the Page Assignment Configuration section.
  4. Select one of the following conditions as described in the following table:
    Table 24-3 Conditional Touchscreen Page Names
    Condition Available Pages
    Employee Class
    Home Pages, Transaction Pages, and Hub
    Revenue Center
    All pages
    Property
    All pages
    Workstation
    All pages
    Workstation Class
    All pages
    Main Level
    Sub Level
    Serving Period
    Order Type
    Visual State
    OCB
    All pages
    Till Assigned
    All pages
    Combo Side Default Level Activate
    Family Group
    Major Group
    Check Active
    Detail Selected
    Order Channel
  5. In the Value column, enter the condition object number or numbers separated by a comma.
  6. In the Page column, select the page to display when the condition is met.
  7. Click Save.
