Setting Up the XProcessor Framework
To use XProcessor, you need to set up the main XProcessor framework and one or more processor plug-ins.
The XProcessor plug-ins are:
  1. Generic SVC - Givex Processor
  2. SVS Processor
  3. ValueLink Processor
The following files must be imported into the Simphony EMC to set up the XProcessor framework:
  • Micros.XProcessor.Payment.dll: To be imported into the Payments module
  • XProcessorConfiguration_initial.xml: To be imported into the Content module
Subsequent topics provide instructions about importing these two files (and each available plug-in) into the Simphony system.
Setting up Multiple Processors
You can set up multiple processors in the same system, but there are limitations. More specifically, the order in which you define the individual processors in the main XProcessor configuration file matters. If you define all three processors, the first processor defined in the configuration file, which handles a specific operation, is the one that is used for the operation.
With the configuration shown in the following figure, the Generic SVC Processor is defined/listed first. Attempting to perform a Redeem function, which is common to all three processors, will be handled by the Generic SVC Processor, even if your intention is to use the SVS Processor.
Figure 37-1 XProcessor Plug-ins
This figure shows the three available XProcessor plug-ins.
This limitation does not apply to the ValueLink processor plug-in as the ValueLink buttons are configured to use a different entry point.
See Adding the XProcessor Payment DLL to the Payments Module and Adding the XProcessor Configuration File to the Content Module for information about configuring the XProcessor framework.
