6 Custom Browser
You can add buttons to touchscreen pages which launch web pages on the workstation. A selection dialog shows a list of available URLs.
Click the Close button to close the web page.
The following error appears when you attempt to access a web page that has not been properly configured: URL is blocked. Your organization doesn’t allow you to view this site. This is a Microsoft Edge generated error message and cannot be customized.
Key Points
The custom browser is supported only on workstations running Microsoft Windows with a minimum version of Microsoft Edge 79.0.309.0.
A Browser User has been added to the workstation for the custom browser.
Downloads are not allowed when using the custom browser.
Policies on the local machine take precedence over those of the new Browser User level.
The custom browser requires CAL 160 or later.
The custom browser uses Page Visibility to restrict access to the web page links.
