POS Keyboard
POS Keyboards can replace the standard alpha-numeric and numeric keyboards on all workstation types with a modern looking version that is consistent across all workstations’ operating systems.
If multiple language layouts are configured, you can rotate through them using the world icon to select the one suitable for your task.
The POS keyboard includes shift and special character layouts and is available in light and dark themes.
Figure 1-10 POS Keyboard — Light
This figure shows the POS Keyboard Light theme, English with Globe button framed in red, Shift (Arrow) button framed in green, special characters (#%&} button in blue, and custom search by options in orange.
Figure 1-11 POS Keyboard — Dark
This figure shows the POS Keyboard Dark theme, English with Globe button framed in red, Shift (Arrow) button framed in green, special characters (#%&} button in blue, and custom search by options in orange.
Where applicable, you can select the ‘search by’ option from up to five buttons displayed beneath the entry field. The first button is selected by default when the POS keyboard is initialized.
