Menu Item Waste Reports
Waste Detail Report
Waste Summary Report
Employee Waste Report
The Waste Detail Report shows in-depth information about wasted menu items grouped by the waste reason, as described in the following table. You can filter the report data by waste reason.
Table 4-1 Waste Detail Report
Column | Shows |
Check # |
Employee |
The name of the employee that created the waste check. |
QTY Menu Item |
The quantity discarded or donated followed by the name of the menu item. |
Amount |
The price of the discarded or donated menu items. |
The Waste Summary Report shows an overview of the menu items wasted and the corresponding waste quantity grouped by the waste reason, as described in the following table. You can filter the report data by waste reason.
Table 4-2 Waste Summary Report
Column | Shows |
Waste Reason |
Quantity |
The Employee Waste Report shows a summary of the waste checks created by each employee, as described in the following table. When you filter the Employee Waste Report for an employee, the report shows a summary of the waste checks created by the selected employee.
Table 4-3 Employee Waste Report
Column | Shows |
Employee |
Quantity |
The Menu Item Waste Report shows the waste reason and the quantity of menu items wasted grouped by menu item, as described in the following table. At the end of the report, a summary of menu items wasted for each family group is shown. You can filter the report by the family group.
Table 4-4 Menu Item Waste Report
Column | Shows |
Item Name |
Quantity |
Family Group |
The family groups of each menu item discarded or donated appear as a summary at the end of the report. |
Quantity |
Parent topic: Menu Item Waste
