Creating and Picking Up Suites Checks
- Press the Pickup Suites Check function key, enter the suite number, and then press OK.
- To create a new Suites check:
- Select a suites owner that does not have a check number from the list, and then press OK.
- If the suite owner’s name is not in the list, select 0 - ADD GUEST, press OK, enter the suite guest name, and then press OK.
- Add menu items to the Suites check, and then end the current service round.
- To pick up an existing Suites check:
- Select a suites owner with a check number from the list (for example, John Smith CHK #435), and then press OK.
- If the suites owner has multiple Suites checks, enter the check number that you want to pick up, and then press OK.
- Make the necessary changes to the Suites check, and then end the current service round.
Parent topic: Suites Checks
