Suspending and Resuming a Check
To suspend a check, the workstation screen should be free from prompts and error messages. When you suspend a check, the workstation posts the check to the database but does not print it. Suspended checks are not shown in the Open Check SLU (Screen Look Up).
  1. To suspend a check, perform one of the following actions:
    • Sign on to the workstation while another employee’s check is open.
    • Click the Suspend Order tender key.
    You can suspend only one check at a time.
  2. To resume a check, sign on to the workstation. You can resume a check only from the workstation that suspended the check.
