Transferring a Check to Another Revenue Center
Workstation operators can transfer checks between revenue centers only when the automatic service charge for the revenue centers are the same. The following table provides examples and explains when you can transfer checks between revenue centers:
Table 3-3 Examples of Check Transfers between Revenue Centers
Automatic Service Charge of Current Revenue Center | Automatic Service Charge of the Check’s Revenue Center | Can Transfer? |
0 |
0 |
Yes |
0 |
1 |
No |
1 |
0 |
No |
1 |
2 |
No |
2 |
2 |
Yes |
You cannot transfer checks between revenue centers that have different Open Check Age Thresholds.To take ownership of a check you must be on the default transaction screen. If you attempt to transfer while in a transaction (a check is open on the check detail area), the workstation merges the checks rather than transferring ownership.
There are two ways you can transfer a check to another revenue center: by check number and by table number. When transferring checks, both checks must have the same order type or order channel assigned.
- To view a list of all open checks in the revenue center
before transferring:
- Press the Add/Transfer from List Prompt RVC function key, select the revenue center that has the check you want to transfer, and then press OK.
- If the workstation has separate touchscreen buttons configured for each revenue center for viewing a list of all transferable checks, press the touchscreen button configured for transferring checks from the revenue center that has the check. For example, if the check is in revenue center 1, press the Add/Transfer Check by List RVC 1 function key.
- Select the check that you want to transfer from the list, and then press OK.
- To transfer a check using the check number:
- Press the Add/Transfer Check by Number Prompt RVC function key, select the revenue center that has the check you want to transfer, and then press OK.
- If the workstation has separate touchscreen buttons configured for each revenue center for transferring checks, press the touchscreen button configured for transferring checks from the revenue center that has the check. For example, if the check is in revenue center 1, press the Add/Transfer Check by Number RVC 1 function key.
- Enter the check number, and then press OK twice to confirm.
- To transfer a check using the table number:
- Press the Add/Transfer Check by Table Prompt RVC function key, select the revenue center that has the check you want to transfer, and then press OK.
- If the workstation has separate touchscreen buttons configured for each revenue center for transferring checks, press the touchscreen button configured for transferring checks from the revenue center that has the check. For example, if the check is in revenue center 1, press the Add/Transfer Check by Table RVC 1 function key.
- Enter the table number, and then press OK twice to confirm.
Parent topic: Check Transfers
