Tendering with OPERA Connection Room Charge
- Press the Room Charge tender.
- If guests are not assigned to the check:
- Enter the guest's room number or last name.
- Select the guest, and then press OK.
- If one guest is assigned to the check, you are prompted with Charge to [Guest Name]?. Select Yes to charge to the assigned guest or No to select a different guest.
- If multiple guests are assigned to the check, you are prompted with a list of all assigned guests (except guests who are flagged as No Post), or the option to select a new guest. Select the appropriate option.
- The tender is applied to the check and prints (if configured).
Parent topic: Check Payment
