Using Consumer Self Pay to Close a Check
The following steps explain the process in which a customer can close a check using an Oracle Payment Order and Pay device for credit card payments or OPERA Self Pay for OPERA Connection on any handheld device.
- After clicking the button that corresponds to Consumer Self Pay on the ordering screen, the guest can change the language, if configured, and select Continue.
 - The check details are displayed, and the guest selects Pay [amount].
 - If configured, the guest is prompted on the device to choose one of the default tip percentages, or if they wish, to enter a custom tip amount or select [No Tip].
 - The guest clicks Pay [amount] to finalize the payment.
 - The following screen flow depends on the payment method:
 - After the guest finishes the transaction, they are prompted
to return the device to the employee.
- If configured, the employee is prompted to enter their ID number to exit Self Pay.
Parent topic: Check Payment
